Chad_Jen
May 15, 2018Explorer
All I could afford wrote:
I work with a guy that has a 2015 Silverado 1500. I believe that would be the same design as yours. We work different shifts, but if I run into him in the next few days I will try to check his seven pin connector to see if the marker light pin gets energized when auto lamps come on, and report back to you.
I believe you're right. Thanks.
44,068 PostsLatest Activity: Apr 17, 2021
