nremtp143
Oct 10, 2013Explorer
I have both products and either will serve you fine. However, there are a couple of differences. The Rhino, as said, is softer and thicker than the Line-X and after a few years, will ruin almost any light colored clothing that is brushed against it. My Chevy has the Rhino. Even though I didn't buy it new and the lining was already there, it has worn pretty well. The others are correct. Things slide less with the Rhino. I just traded a '10 F350 last Friday that I had sprayed with Line-X. The color did fade a bit, it is harder and things do slide a bit more. Both have great warranties as I did gouge the Rhino with a pallet which was repaired quickly and easily. Now, my camping buddy has the Ford spray in liner in his '12 F350 and it is not near as thick as the Line-X and the truck has been garaged so the jury is still out on that one. Just had my '13 F350 sprayed with Line-X yesterday with the upgrade to the product that is not supposed to fade as the previous one did. Time will tell.
