Huntindog wrote:
I do not know what "rolled" means. I DO know what welded looks like. I have seen that on many TTs.
I DO NOT have a welded frame rail frame.
It is what I consider to be a "normal" I beam.
Simply put there are two methods used to make a structural shape. Hot rolled or cold rolled. Specifically in relation to an H or I which are a complex shape, there are two ways to make them. Hot rolled is steel goes in one end of a plant, and an I or H comes out the other. Its then shipped to a fabricator who cuts it, drills it, fabricates it.
The other way to make an H or I, is you take 3 pieces of plate or sheet, and weld them together. That's it, two options. You can cold roll a C, or an angle, or a Z or a bar, and a lot of other shapes, but you can not cold roll an H or I. Those are the simple versions. This
Article explains it better than I can.
All of that said I am not saying an engineered/machine welded member is a bad thing, as I have built a couple million square feet of pre-engineered industrial facilities. Almost every beam, frame or column, and almost every structural element in one, is engineered and made from machine welded shapes. We have hung some overhead cranes from them at times. Its all about it being engineered correctly.
I don't know how one can say "I DO know what welded looks like. I have seen that on many TTs. I DO NOT have a welded frame rail frame."
Frankly if the equipment used to weld those 3 pieces together is maintained and set up correctly, you're not going to be able to tell visually as that weld will be smooth as a babies rear end. I've seen a few of those machines at some of the fabricators that actually can grind the welds as part of the process, and once painted you need to no what you're looking at to tell. But it can usually be determined simply by "size".
Here is why I think you're mistaken and the 10" high frame rail in your picture is a machine welded piece, and not a conventional hot rolled member. They make hot rolled H shapes (we call them a wide flange or W) or I shapes (A Jr / I, or S), only in specific readily availible sizes and weights. Going by your picture the flange width is roughly 2-1/2" wide. I determined that by comparison to the two fittings installed on the black tank. One is 1-1/2", the other 3".
There is no H or I which is hot rolled that a company like Lippert could buy from a hot mill, that would be those dimensions in a 10" height. It simply does not exist unless its a custom hot rolled shape and cost would not typically allow that.
In your picture you have a 10" height, a 2-1/2" flange width, and a 1/4" thickness both at flange and web based on the measurements you took.
Here is what you can get from a hot mill.
There are a couple dozen made with a 10" size in a wide flange, but none including the lightest which is a W10X12(lbs per ft), has a flange width smaller than 3.960 inches. Then they go up from there. The only size in a wide flange that has anywhere close to 1/4" average thickness at both flange and web is a W10X15, with a 4.00 flange width. The web is .230 and the flange is .269
There are only two readily available sizes in a Jr/I/S with a 10" height.
S10X25.4 or 10.000X4.661, The flange is 4.661 wide, and the thicknesses are flange .491 / web .311
S10X35 or 10.000X4.944, The flange is 4.944 wide, and the thicknesses are flange .491 / web .594
That's why I think your main rail is an engineered / fabricated / machine welded shape. That is unless Lippert is having hot rolled shapes custom made at great expense, or own a hot mill and making their own. Not sure why they would want to. The size is not available unless its fabricated. Maybe I'm wrong.
