LVJJJ
Jan 29, 2018Explorer
Lippert frames
Been towing for 30 years, but never heard of a Lippert frame. Seems like most of the comments are negative.
So, what is a Lippert frame?
SoundGuy wrote:mountainkowboy wrote:
Lippert has been building garbage for many, many years now, and there failures are well documented. I wouldn't buy anything they build, I've seen better welds from teenagers.
Then I guess you won't be buying anything as Lippert is all over the RV industry with a wide range of products. ;)
drsteve wrote:
The 2018 Coachmen in my sig has plenty of shoddy workmanship, the most serious being a floor that flexes and makes loud cracking sounds when walked on in front of the stove. Coachmen customer service rep says this is normal and that they all do it, even though I was unable to find another one on the dealer's lot that did. The dealer is useless--they proved unable to even properly install a slide awning--and so is Forest River.
Huntindog wrote:goducks10 wrote:Huntindog wrote:
My present TT has a Lippert frame. It is by far the best frame I have had under any of my TTs.
10" tall real I beam (not welded) 1/4" thick.
The welds are top notch, and the frame is powder coated.
Lippert gets a bad rap here, but my frame is proof that they can put a good frame under a TT, if the manufacturer is willing to pay for it.
I had a out of warranty problem with the Lippert sealed bearing axles my TT came with. Lippert had discontinued those axles, but made me a very fair offer to get both axles replaced.
They could have easily weaseled on me, but they stood up and did the right thing.
I know I may be a rare bird here.... But I am a Lippert fan
I highly doubt the web is 1/4" thick. If so that TT would weigh way too much.
The flanges would be 1/4" where they meet the web.
Just curious what TT do you have?
2010 Palomino Sabre. 30BHDS
The web and flanges measure 1/4 thick.
I am not set up to post pics. I do have pics of my frame on the factory floor. from when I toured the factory after picking it up.
Jbarca has seen them.
I don't BS about this sort of thing.
SoundGuy wrote:
My 2014 Coachmen Freedom Express has a pressed together Lippert frame that has cracked near the rear tires on each side. :M
As to the OP's question, my understanding is that newer models now use a different frame that shouldn't exhibit this frame cracking problem that have plagued so many Freedom Express owners.
GrandpaKip wrote:
If you truly believe this, then why in the world do you keep recommending this trailer?
GrandpaKip wrote:
....snip...
SoundGuy wrote:
My 2014 Coachmen Freedom Express has a pressed together Lippert frame that has cracked near the rear tires on each side. :M The parent company Forest River has been forced by NHSTA to issue a RECALL for specific models lacking required frame stiffeners. Unfortunately, even though my trailer was built during the time period covered by this recall my particular model is not on the list because it does have these frame stiffeners - yet the frame still cracked. :M For this reason both Coachmen and Lippert denied a claim made by my dealer on my behalf to have this frame repaired ... he's since gone back at them repeatedly and in a recent email says that Lippert has finally now agreed to cover the cost of repair. I'm certainly not happy this Lippert frame has failed and the reasons don't really matter to me but I am now satisfied I'm not being left holding the hook on this. As to the OP's question, my understanding is that newer models now use a different frame that shouldn't exhibit this frame cracking problem that have plagued so many Freedom Express owners. Whether this same improvement has been made to other Coachmen models or other manufacturers' models I couldn't say but if I were in the market for any trailer that had a Lippert frame I'd want to know that it was up to the task.
Wild Card wrote:
Mine is not a welded 10" I beam as well. Can't post pics...don't do the host deal.
