exploringcaroli
Nov 01, 2013Explorer
Used to tow a 1000lb 2004 LTW Chalet A-Frame pop-up (low wind resistance) with a 1987 Toyota 2.4L 4 cylinder pickup getting 22 mpg @ 55MPH non mountain areas.
Towing the 1500lb CampLite 11RD with a 2003 2.4L 4 cylinder Tacoma @ 55MPH gets 16MPG non mountain areas.
Towing the CampLite with the 2013 4.0L automatic Frontier @ 55MPH gets 15MPG non-mountain areas. Fuel economy drops to 13MPG @ 65MPH with same TV.
It's easy to get into small sites with the CampLite 11RD or small pop-up that larger campers cannot get into.
This morning when leaving a small site on the ocean front @ Hunting Island SC, the easiest way to pull the camper out was to turn the camper "manually" 180 degrees on the site. Used two small pieces of plywood under the tongue wheel/jack. Took about 15 minutes to turn the 1500lb camper 180 degrees on sand and pine needles. That would be difficult with a larger and heavier camper.
Have been looking at larger CampLites & Fiberglass campers. For now will be keeping the CampLite 11RD.
We started transporting two bicycles inside the CampLite:
Best fuel cost this week $2.99 per gallon in SC. Earlier this week @ Hunting Island SC:
