Dbegno1
Jul 10, 2014Explorer
I have a 6x15 Toyhauler made by Livin Lite. I installed the Sensa Tank system from LevelGuard Products. After much research it seemed to be the most dependable and easiest to install. It simply tells you your level in thirds.The sensors adhere to the outside of the tank. I am in the electronic/process industry and am very familiar with various level sensing technologies and am amazed at the technology used in their system. For the battery I installed a Trimetrics monitor from Bogart Engineering. It gives you voltage levels, current consumption, battery charge, etc.
I must caution you to only tackle one project at a time because each installation has wiring procedures that are not too complicated but need to be followed exactly. Don't use crimp type connectors wherever possible,use solder and heat shrink connections and they will be trouble free for a long time.
I will try to follow up with photos.
44,071 PostsLatest Activity: Aug 16, 2026
