CampingN.C. wrote:
plasticmaster wrote:
Could it be that my truck's leaf springs are worn out? It is 14 years old with 227K miles.
That info would have been more helpful in the OP.
I sort of assumed the springs were giving up the ghost when he said "Then it started to sag in the rear." And yes, I've heard the joke about assuming ;)
The instructions on my Husky hitch says "There should be at least 5 links between the lift bracket and spring bar." I've interpreted this to mean it shouldn't be hooked above the 6th link, leaving 5 between. It also says "The spring bars should be nearly horizontal when correct height is achieved."
