CapriRacer wrote:
Does your RV have a vehicle tire placard - located on the front drivers side lower? What does it say for size and inflation pressure?
How old is the trailer? Still trying to sort this out, but it was common for many travel trailer manufacturers to use too small of a tire.
What brand of tires? What country were they made in?
Actually most TTs came OEM with just adequate tires. They only needed to match the axle rating, usually just a bit above.
The placard likely shows a D-rated tire for that size trailer, with 65 psi for inflation. The E-rated tires would likely be an upgrade by previous owner.
Jerry
