Joe417
May 30, 2019Explorer
It won't be a problem if you level the truck first (especially side to side) as Maxum1989 said.
My driveway was very un-level for years. I could get the TC in and out but it was a pain, very uncomfortable. I've learned a bit the hard way.
I ended up bending the two right side jacks as they were on the low side and start to tilt the camper back to level as you raise it. I didn't "do the math" until I had damaged them.
The jacks bow because they touch the ground inboard of vertical. As you raise the TC to level, the jacks won't slide, they bend slightly.
I did it 4 or 5 times before the jacks were bent enough that the motors started pulling too much current and blow the right side fuse in the controller. Use some 2x's to level the truck and you should have no problems.
I've built a pad for loading and unloading the TC, but haven't replaced the jacks yet. The gravel was much cheaper than a set of jacks.
