Freep
May 31, 2019Explorer
billtex wrote:
You have four jacks on your camper. Place some plywood or metal plates under the feet. Load/unload as needed. Don’t over think it. I have unloaded camper on some crazy uneven ground-no worries-just go slow.
I load and unload on uneven ground a lot at home. It helps tremendously to have an experienced spotter and to go very slow. The truck may look lined up perfectly going in but then you need to adjust while halfway or further under the camper due to the uneven ground. It's amazing how much you can adjust without giving up and starting over.
Most of my adjustments end up being something like turning the wheel all the way to the right and move about an inch or two, then straighten out.
It's certainly not a fun exercise but it can be done, depending on how uneven the ground is.
