mkirsch
Oct 28, 2013Nomad II
The camper's designed to be USED unsupported, not HAULED.
Walking across the floor is a whole lot different than rattling down the road at high speed for thousands of miles.
Using plywood to "support" the floor is a joke. Reach under there and pull down. You can create a several-inch gap between the rear edge of the plywood and the floor of the camper with very little effort, even with 3/4". The plywood is offering ZERO support; it's just adding weight.
All I can say is, haul it like that, or don't. Completely up to you.
I personally wouldn't unless the camper was a "short bed" model, but you have clearly specified that it's a "long bed" model. The designers designed the camper to be supported along the first 8' of floor. You may break it's back, you may not. Have a contingency plan in place just in case, and remember you have no one to blame but yourself if things don't work out.
