jonmad
Mar 20, 2015Explorer
Long shank question...
I would like to be able to drop my truck tailgate while connected to my TT. I have a long shank but was wondering if there is any reason not to use it?
wing_zealot wrote:The payload capacity does not change, but the further aft of the rear axle that your ball is located increases the weight on the rear axle, and further decreases the front axle weight more than a normal hitch setup. This is due to increased leverage on the rear axle.
Why should it? The payload capacity doesn't change if you are towing a 5th wheel (with the payload directly over the axle) compared to a TT (with the load out a ways from the axle). So why should it change if the load is at 36" away from the axle vs. 34"?
