carringb
Jan 29, 2016Explorer
Oh I just though of one more issue I've had, and could affect others too. The shower drain is a slip coupler (not-uncommon) however the pipe is un-supported, and must have a flex couple somewhere down the line. Mine came off, draining the shower into the underbelly. Probably shaken loose from washboard roads, and its easy to access since they included an access panel. But, all ORV owners should check the slip fitting and add a support as needed.
44,071 PostsLatest Activity: Aug 30, 2026
