4X4Dodger
Feb 10, 2015Explorer II
DustyR wrote:Huntindog wrote:4X4Dodger wrote:LarryJM wrote:All I could afford wrote:
It would tend to increase trailer sway as well as multiply the effect of your tongue weight putting more weight on your rear axle of tow vehicle.
Try it and see, if you can get the ball mount for a reasonable price.
I've been using the longest drawbar available for the last 30+ years on two different trailers and have noticed no adverse effect. The impact is IMO so minor as to be insignificant in the overall scheme of things and distances involved.
I use the longer draw bar so I can full open the rear doors on my Van without hitting the jack. IIRC my drawbar is around 15 to 18" or about 6" longer than a standard drawbar. I understand some drawbars have multiple holes with different ratings, but mine has a single hole and it's so old it doesn't have or the rating stamp is long gone, but it's solid steel and heavier than sin and is not cast, but welded out of 2" soild square steel stock.
Larry
Larry
Can you tell me where you got this longer ball mount/draw bar? I have looked all over my area and on the Reese web site to no avail.
I currently have a class V 2 1/2" Reese Titan
Like you I want to have room to lower my tailgate while hitched.
Thanks
My drawbar
Another Choice:
My Hitch/Shank
Thanks to both of you for your suggestions. That may be the way I have to eventually go. I was hoping to find a Class V 2 1/2" Drawbar/ballmount similar to the pic below. All one piece but longer by about 6" from the hole in the shaft to the C/L of the Ball Mount. Checked Reese web site and a few others but nothing so far.
