Johnnybgood's avatar
Johnnybgood
Looking at truck campers
The wife and I are looking to get a truck camper. The problem is we need something that can withstand Illinois winters. We are year round 1/2 timers. We would be using this in the parking lot of our work during the winter instead of driving the 28 miles in snow and ice everyday. Winters here get down to -20 to -30. We would be using it 3-4 days a week. I know Artic Fox is good, Okanagans, Big foot as well. Any of these I need to take off the list or more I can add to the list? Thanks John
  • John,
    I know the area well as I spent part of my childhood near Taylorville and still own some farmland inherited from my Granddad near Blue Mound.
    Six inches of insulation under the floor, combined with a "skirt" will help.
    Blocking the cracks in the slide openings with blankets or towels will help a little more.
    Get some 1/4 inch bubble wrap and cover the inside of the windows with two layers (bubbles against bubbles) - it lets the light in and keeps the cold out.
    Each one of the above will make a small difference but all of the above will make a big difference.
    e.i. "The whole is greater than the sum of its parts".
    BTW - My heat sources:
    Primary - 1500 Watt oil filled radiator, controlled by a Lux WIN100 thermostat.
    Secondary - 1250 Watt Utility Heater, controlled by another Lux thermostat.
    Backup - the propane furnace.
    Primary thermostat is set for 75°F
    Secondary thermostat is set for 72°F
    Furnace is set for 68°F
    Last winter, the furnace ran for about 15 minutes total time.
  • My first suggestion would be to call Lance customer service in Lancaster, CA and talk with them. They certainly can tell you what you would need if you were to order a Lance. Another good source is David at Galaxy Campers in Ontario, CA they are the country's largest Lance dealer and they only handle Lance TC's so they are experts.
    When I had my Lance the coldest I ever used it was 7F. It was toasty except wish I had more insulation under the mattress in the cab over.
  • Decatur area. Our Hitchhiker II has single pane windows and I did not put anything down to block wind going underneath. It was not a good winter. I figure to add insulation between the truck and camper where there is dead space to help keep the winter out.
  • John,
    Where are you in Illinois?
    I usually "winter camp' about 5 miles South of the "Cheddar Curtain" and I had no problems when the temperature was 22° below zero last winter.
    My rig has the "Arctic" option (double pane windows, extra insulation, NO slides, etc.).
  • For those conditions I'd be thinking of building something myself. I'd want 3-4" of Styrofoam, like a cooler. Make like an igloo where a small amount of heat would keep it cozy. Keeping any water tanks inside the insulated shell. One access hatch for everything, double sealed and insulated. Your talking Alaska conditions, Brrr.
    I love my HitchHiker II but not in those conditions, don't blame you. But have you considered finding 1/2 time employment in Florida?
    Just thought of what you need. An ice fishing shanty on a truck. Somebody in Green Bay should have some plans.
  • We use our Lance when we snowmobile in the mountains..15-20 below at 10000ft...it stays toasty. But no water....I would try to find a used BF..but hard to find...I used to stay overnight in Melrose park IL in a parking lot in the winter...stayed toasty for 8 hrs. of sleep. But no shower...look for a unit with thermo pane windows
  • It is in what is somewhat affectionately called "The pit" It is a part of the parking lot that sits lower then the parking lot/ground arround it so it is somewhat protected from wind. It still gets really cold though. We camped there in an older class c and as you can imagine we went through a lot of propane. Not all winters here get that cold, but this last winter was a doozy. We wintered in a Hitchhiker II fifth wheel in a trailer court. The cost and time to travel in that weather has us looking at something else. We will sell the fifth wheel after making our truck camper purchase.
  • Whoa, that's awfully cold for a camper! Is the area covered that you plan on staying in?
