Padlin's avatar
Padlin
Looking for better rotors
After one trip down the Bighorns my rotors warped, pulsing pretty bad, seemed the right front wheel was very hot compared to the rest and had a heavier dust buildup on the rim. Had the Ford dealer in Cody Wy check them out, for $400 they turned the rotors telling me they had all overheated. 2 days later the brakes still pulsed on the downhill into Yellowstone. Right or wrong we finished the trip putting most of the braking on the trailer brakes via the manual lever and avoiding the worst of mountains.
Before I bring the truck into my regular mechanic, I'd like to look into the possibility of better then stock rotors and the applicable pads. If anyone has looked into such, I see slotted, drilled, slotted and drilled, and slotted, drilled, and dimpled, do any of these actually make a difference in heat dissipation?
2012 F150 4x4 Heavy Payload (17" 7 hole wheels), 30k miles, IBC.
FW weighs 5000 lbs, new this summer.
  • Bob I would check out Power Stop Brakes I had good luck with them. They make a server duty brake kits that shouodl work for you. Quick question does your ecoboost not engine brake very well? I went to yellowstone last year and went through several steep declines and almost never used my brakes. My engine did 90% of the braking and I maintained a safe speed. I have 70,000 miles on my truck and 30,000 of them towing and still have 75+% of my pads left.
