dmcf wrote:
Just bought a new to us 2006 KZ Frontier 2405 TT, and I am towing with a 2007 Nissan Armada. Before this TT I was towing a Antigua 215SSO, which was about a foot shorter, and 1200 lbs lights. It towed great, but I do not enjoy towing the new trailer. I get some sway, and we are bouncing all over the place. Currently using basic WD bars, and a simple friction anti sway bar. So, I am looking for a new set up with much better sway control. I just watched a video on the Anderson Hitch, and I like the setup, but not sure how well it works. Anyone have suggestions of systems I should be looking at?
Thanks,
Darren
IF you are getting sway. Your trailer is not properly balanced, and or your hitch is not properly setup. Tire not properly inflated, Ect. A fancy sway control system will just hide the problem. That is very dangerous. Fix the problem.
Your new TT is 1200lbs heavier. Have you adjusted the hitch to compensate for the added weight? If not, you have unloaded the front of your TV, causing sway.
