Need-A-Vacation
Sep 18, 2016Explorer
Rick,
Welcome!!!
Regarding the trailer in question, you will actually have a ~600lb tw once the propane tanks and a battery are on the tongue. Not sure what the layout is, or how you may pack, but you generally need 12-15% for a safe, stable tow. Yes, some trailers may be ok with a little less, but others like a little more. Last thing you want is to find out the hard way. If the tt is ~6500lbs loaded, you could have a tw of ~780-975lbs (12-15%). It looks like you will be under the receiver hitch rating but hard to say about the tv payload. The other number to watch close is the rear axle rating (rar).
Make sure you get a good wdh w/ integrated away control. And the correct rated wd bars for the loaded tw. That is a little longer tt for the slightly shorter tv you have.
Good luck!!!
Welcome!!!
Good luck!!!
44,056 PostsLatest Activity: Jan 12, 2020
