APT
Sep 19, 2016Explorer
Travel trailers do not tow well at 9 percent TW. You will want 12-14. When you use a WDH, some of the loaded TW is carried by the trailer axles. Most TTs under 6k dry should work well for you. Use a WDH with integrated sway control. Use tow/haul transmission mode.
This assumes that you have 5.7L/4.30 axle so power is not a problem.
44,056 PostsLatest Activity: Jan 12, 2020
