camp-n-family
Sep 19, 2016Explorer
Your tongue weight will be higher than you think and will probably put you right at, or even slightly over your payload number. With that said I still think you'll be fine towing that tt. Payload numbers are only one factor to consider and are very conservative. A hundred pounds over isn't going to hurt anything. I'm not saying you should ignore it but I wouldn't base my decision on that alone. More importantly you will be well under the axle and tire ratings.
If you're really concerned about staying under payload consider that a portion (~20percent)of that tongue weight will get transferred back onto the tt axles through the use of a wd hitch. See if the dealer will let you hook up and go to the scales. It won't be loaded but will give you an idea of actual weight.
44,056 PostsLatest Activity: Jan 12, 2020
