westend
Oct 26, 2017Explorer
Cut the vinyl in a very small "X", over the screw. Remove it or glue it in where it should be. Fill any indentation in the floor surface. Either buy seam sealer at the big box store or, as a last resort, use clear nail polish to adhere the edges of the "X" cut.
I have, successfully, sometimes, been able to drive a fastener back down from the top with a drift and a small chip of wood. I've also had to pull up a whole new floor because of popping screws. Good luck with your vinyl problem.
BTW, most screw problems on subflooring happen when a screw head separates from the threaded shaft. That is caused by too much torque from the installer.
44,066 PostsLatest Activity: Oct 04, 2013
