webwrangler
Nov 10, 2016Explorer
Dinette rattling loose from floor
I'm now on my third attempt to secure the dinette seat in my 2005 Rockwood 2104. This is an aluminum frame trailer, and the dinette is framed from the same material. Vibrations and rattling have caused the original screws to work loose and the holes to be unusable. I have been known to take the TT down some washboard roads to go fishing!
On the last go-round, I used subfloor adhesive to glue the aluminum frame to the floor and the side of the trailer where the seat back is attached. I also put plastic anchors in the floor before re-attaching to the floor with bigger screws.
The glue wasn't such a good idea--it stuck great to the vinyl flooring, but pulled the vinyl loose from the subfloor. It held for a while where the seat back attaches to the wall, but eventually it gave out, too. Alignment was a problem with the plastic anchors; I discovered that I only got a screw into one, with the rest of the screws going into the subfloor like the original installation.
So now I'm looking at using toggle bolts on the seat back. It turns out that the seat back is aligned with doubled-up vertical aluminum square tubing. I think two toggles into one of the wall tubes should hold there with some loc-tite on the threads.
I don't want to just put screws in the floor again, even if I put them in new locations. It seems to me they'll eventually pull out again. I've thought about bolts all the way through to the underside of the trailer but I don't know if the underside is durable enough to hold the nuts, even with washers. It appears that I have the subfloor, some styrofoam insulation under that, and a layer of some kind of paper or cardboard covering the underbelly (!) The underbelly is not enclosed.
Does anyone have a suggestion? I would like to make this the last time I have to fix this; the wife is not on board for a new TT and I have a lot of trips in my future.
Thanks!
Thanks!
