towpro's avatar
towpro
Lost contents of refregerator
When not in use my Wolf Creek sits on solar. So I run the refrigerator on Propane all summer.
every couple days I check the propane regulator to see if its Red, maybe bang on the bottle to hear the sound difference, and check the refreg temps.
were getting ready for an extended trip, I open refreg, its 85 deg :?
everything in freezer is thawed.
Turns out the propane switched over, ran both tanks dry but regulator never turned red.
This regulator is only 2 years old. color changes if I turn off bottles one at a time and test it.
I really hate the way RV parts quality seems to have gone to hell.
Remember when change over regulators always worked?
  • Lantley wrote:
    The technology exist to resolve this issue.Get a trma level check. To easily check your LP level. They are not cheap but they are cheaper than losing a fridge/freezer full of food.
    Thanks Lantley. I just bought the one Dometic stamps there name on from Amazon for just over $32.00
    click here
    I paid a couple $ more and bought it direct from Amazon so if it don't work I can return it no questions asked. I do maintain 8 LP tanks between RV's and grills, maybe this will make it easier.
  • towpro wrote:
    (a tank fill cost $6.00 where I live).
    WOw... that's dirt cheap for propane. I can't fill my tank for under $25.00 for each one.
    click here
    Very cool doo-dad, but how does it work?
  • trail-explorer wrote:
    click here
    It will be here tomorrow :).
    click here
    I'll just note that I have the Domestic. First one I got rattled and didn't work because the "cages" which hold the battery were loose. Second one worked but I just dropped it in the dirt and sure enough the batteries are loose again. I may try and re solder them but not sure it will work. I suspect the Truma is much better made.
    Truma level Check
    HMMM .....I didn't know this technology existed. Not knowing the tank level is always frustrating.
    I found one on Amazon that is a little cheaper, and uses the ultrasonic technology also....and has pretty good reviews. I may get on and see how it works.....Some of the reviews say it works on some tanks and not others ....If it doesn't work on mine I'll just send it back.
    Link
  • brholt wrote:
    click here
    Note I have the dometic style/type as well. It does not work as well as the Truma. It sort of works OK but you have to fuss with it to get an accurate reading.
    I recommend the Truma over the knock offs. In this case taking the savings was not the right move. I should have paid for the one that works with ease vs. the cheaper erratic model ....LOL
  • Thanks for the info .... may have saved me some hassle.
  • Replace with Cavagna brand regulator. Search Amazon. Indicator seems to have a superior mechanism.
  • this dometic device seems to work good. put one hand on top of tank, than with other hand, push device up against tank (device square with side of tank), the tip collapses a little to activate it. if the LED is red, that cross section is empty, if its green, that cross section is covered with propane.
    tried it on several tanks, seem to reflect true measurements :).
