One of the problems with a too large AC is that it will short cycle and not dehumidify well. We have a large teardrop trailer with about 400 cubic feet and I did not want to have an RV type AC because of height and it would really short cycle. I adapted a 5,000 BTU window shaker with an insulated plenum on the front that takes two 4" hoses and goes through two marine deck plates in the side of the trailer (after first making sure there was no frame in the way). The controls from the AC were removed and put in a project box which is attached with wires through the intake hose. I did run into a problem with the coils icing and installed a bilge blower in the hose with a PWM controller so I could vary fan speed.
The advantages are that I can leave it home when we do not need it, because there is no mechanical connection it is virtually silent and to replace it is a simple matter of a hundred or so dollars (I picked up a replacement AC for $50 end of season).
