azrving
Jan 07, 2015Explorer
Welcome and welcome to the club of rv modifications. It's a pretty common upgrade and obviously you already know exactly whats going on. Condense the pump run time and avoid the constant on and off. I did it with about a 2 gallon tank from HD and put 2 ge (?) in line filters in. I also plumbed it so my winterizing valve can suck water out of a 5 gallon jug and put it in the fresh tank. Put an extra gate valve next the the bladder tank and it pumps straight to fresh. Dont have to lift the jugs to fill my holding tank. I'm old.
Also helps on the noise a little if you cushion the pump mounts and go to flexible hoses.
I like to be able to hear it a little and as I tell people, it's also a diagnostic "tool" to pay attention to. If you hear it kicking on momentarily for just an instant when you haven't turn anything on it can often mean a small leak somewhere or internal pump leakage.
I found a water heat leak that way. Problem is that things start getting destroyed and people dont realize it.
As far as pressure and volume we dont seem to have any problem with showers or most distant kitchen sink with 14 yr old pump.
