tcp
Jan 08, 2015Explorer
I added one of the small RV sized bladder tanks and, while it helps a bit, rubber mounting the pump and adding foam insulation around the PEX pipes near the pump helped much more to reduce the noise. It' seemed to be the pipes rattling against nearby wood cabinets causing most of the noise. Soft hoses at the pump connections would help a lot. As well.
