handye9
Jan 08, 2015Explorer II
Most of the noise is from the PEX lines, and in some cases the pump itself, vibrating against the floor or a wall. Adding flex lines and foam cushioning quiets it down considerably.
If you were to add some type of bladder, you would either need to add some type of drain and bypass, or, use a lot of antifreeze to winterize. The large amount of antifreeze option, would also require a lot of flushing to clear it out.
