kevden
Jan 08, 2015Explorer
On our old TT I had to replace a bad pump. I mounted it on a foam pad and used a braided hose from home depot on the outlet side, and put pipe insulation between the cabinet and the flexible pipe. That quieted it down significantly. I do like to hear it a little, otherwise it may run continuous if the tank is dry or if there is a leak. I have not done this mod to our current TT yet.
