Jetstreamer
Jan 09, 2015Explorer
I have my pump on a rubber "mouse" pad in addition to some braided washing machine hoses which are formed in a loop. Pump runs quiet. It is true like some have said that it is acceptable to have some "quiet" pump noise just to make sure it's working correctly.
I am a big proponent of a pressure tank. Why not have the pump cycle less and be able to run a gallon or two out of the faucet without having the pump going. I have a two gallon model (fits in an egg crate) and I don't think one would need anything bigger unless you had a whole bunch of extra space.
Be careful with the type of pump you run with a pressure tank. Some models have a bypass system on them that reduces flow just before the pump shuts off to ease any pressure bumps. I have found these very hard to adjust to work with my tank.
I run mine at close to 50 psi with no issues.
There aren't any winterizing issues nor will a pressure tank setup necessarily use anymore antifreeze than without a tank. When filling antifreeze you just run the pump, let the tank fill slightly, shut off the pump and then distribute the pink stuff through out the system. When it comes time to drain any liquid out of the pressure tank all that needs to be done is to turn on a tap with the pump off and the air precharge in tank will drain it out.
