OK. Regardless of all of this, I'll be getting a new battery. Went to Harbor Freight and got a cheap load tester and a CenTech 30a Circuit Tester #67724. Also cheap. It replaces the fuse and reads the amperage. I could get the battery to read bad if I kept the load on for 10sec. Interstate RV/Deep Cycle. 405CCA, 505MCA.
Fridge circuit .8-1.3
Propane detector circuit .2
The TV antenna is on one of the circuits and can't be turned off like in our last camper.
Converter voltage 13.6
Voltage at the truck plug 12.6
So, is the AGM battery worth the extra $100 compared to a flooded battery?
When parked at home, the camper is always plugged in. Good or bad? Or should I just use a battery tender?
Thanks for the input and help...
