calabria1922ExplorerNov 01, 2014Lowering Truck and Effect on TowingI have a 2008 2500HD CC/SWB/2WD that I use primarily for towing a 13,000 lb. 5th wheel and I want to lower the truck 2-3 inches to give me more clearance between the top of the bed rail and the unders...Show More
dodge_guyExplorer IINov 02, 2014You can usually remove the spacer blocks or, if necessary, add shorter ones.
Related ContentTowing lights issueTow RatingsCost effective 14,000 tow ratingLowering tow vehicleCause and effect?
