Cummins12V98 wrote:
joelc wrote:
On my tires it states 80 lbs pressure. That is what I leave them at towing or not. However, if you want a softer ride I would follow the guidelines on your left vehicle door jam, but not any less.
Must be a real pleasure riding with you.
At least you know you are safe. The manufacture puts a specific recommended pressure stamped on the tires for a reason. The vehicle manufacture puts another pressure on the door jam so you get a softer ride, but not generally safer. I would vote for the tire manufacturer specs, not the truck manufacturer suggested pressure. Check it out.
