wilber1 wrote:
Cummins12V98 wrote:
Wilber buddy do what you want, call it what you want I explained what works and how. Oh and let's not forget I get by far better mileage and perfect tread wear than most by using the charts.
Your opinion only. The charts claim no such thing, they only give maximum loads for different pressures.
So you are unable to relate to one knowing the actual weight on an axle and setting the pressure is the tires a little above that weight based on the inflation chart. With your lack of logic, I maybe should be running 80 PSI in my front tires verse what the door jam says because they are the same tires all the way around! At any rate enjoy your bumpy ride, decrease braking and handling!
