canoe_on_top
Oct 01, 2013Explorer
Shouldn't have a problem with water freezing at those temps. Make sure your propane tanks are full and run the generator a couple of hours each day and you should be fine. I don't like the idea of combustion inside the TT. Condensation is an issue and if you leave the windows open to make it safe you loose the heat. Use your furnace, that's what it's for. Especially with little ones.
44,068 PostsLatest Activity: Jun 17, 2026
