K_Mac
Apr 02, 2019Explorer
LP Detector
I'm in need of a new LP detector to replace my Safe T Alert 40-442P. My friend got a new one that mfg. date was 2 yrs.old when he received it, so on a 5 yr. life he's already down to 3. Where have you...
h45wt wrote:K Mac wrote:
I'm in need of a new LP detector to replace my Safe T Alert 40-442P. My friend got a new one that mfg. date was 2 yrs.old when he received it, so on a 5 yr. life he's already down to 3. Where have you gone via. the net. to avoid this from happening ? Also have any of you gone the LP/CO2 combo and are happy enough to recommend one or just the LP model. TIA K-Mac.
As far as I have been able to find out for the MTI units the internal 5yr clock doesn't start until the first time power is applied to the detector and I also believe there is an internal battery for the 5yr timer so pulling the fuse to increase life span doesn't help. If someone still has their old unit they should tear it apart and see if there really is a small coin type battery in there. I do pull my fuse each winter and this summer will be my fifth year so I should know in the next several months what happens. Most of the units have a special alert that indicates your 5yrs is up. Pushing the reset usually gives you 30 days before it can't be reset.
