_1nobby's avatar
_1nobby
LP Gas SwitchOver Valve Thingy
Can an RV LP gas switchover valve go bad?
OK, ok...I guess anything can go bad.
But how common is it?
I have (had) 2 full 20lb tanks with only one turned on.
I pulled off my plastic tank cover to get at the batteries mounted behind....and when I did...big stink of gas and a nearly empty tank.
I put leak detect on everything with no leaks found....the only unknown is that switchover regulator thingy.
