The manufacture states that my 2018 Sonoma has two 20# LP tanks. Does that mean gallons? On the tanks themselves it says 8.5. I am unsure what these numbers mean. At any rate it wasn't enough for a 4 ...
A 20# tank holds about 4 gallons of LP. Two of these should be more than enough for 4 days unless you were running something requiring a lot of propane like an LPG fired generator. Are you sure they were both full and both are now empty? Most newer trailers have an automatic changeover for the tanks to keep the propane flowing. When one is empty it changes to the full one (if both valves are open).
