Sauropod
May 29, 2014Explorer
LPG Hot Water tank pop-off valve erupted - is this normal?
Hello! I looked through the forums but didn't find exactly my situation. We are first time pop-up owners (2009 Starcraft 2406) and I took it out for an extended adventure the last 5 days. I fired up the hot water heater in order to try out the shower. Though my intent was to use the shower within minutes of firing it up I was delayed by a photo-opp with an elk :-). About 10 minutes after lighting the hot water heater the pop-off valve did its thing and water was pouring out of the external vent. I carefully turned off the hot water heater. The upside was the shower's water was, indeed, hot-hot-hot. I used it again 2 days later but this time I made sure to shut off the flame as soon as I was done with the shower.
Here is my question: On a 2009 Starcraft 2406 (or any other pup w/ LPG water heater) must I light it, use it, then shut it off immediately? I was under the impression it was like the water pump that auto-pressurizes as needed. I presumed once I lit the hot water burner that, if it became too hot, it would back off the heat or shut down completely. However presuming isn't knowing :-) thus my coming here. Before I left I put in a new pop-off valve, new thermocoupler and new element as they were all original and I didn't want any troubles like I had with my initial voyage which saw the factory converter go bad (thanks WFC for the easyish-to-install replacement!).
