Truncating all the previous posts:
Groover wrote:
What you say makes a lot of sense to me as an engineer (though not a tire engineer). I would like to add that the rating on the side is a MAXIMUM pressure and a Maximum load so they need to be read in that context. Likewise, most wheels have a maximum pressure rating. If yours don't I would assume that it is no more than maximum pressure rating of the original tire. While I agree that wheels rarely fail I feel that there is a good reason behind the ratings.
One of the things that I believe causes confusion among consumers is that tire pressure vs weight capacity charts don't seem to be available for the tires we use. …..
They are available, but they are largely unneeded, because ALL light vehicles (cars, pickups, and the like) are required to have a vehicle tire placard which will list the original tire size and the specified pressure for that size - and all the tire maufacturers will tell you to use that.
The exception to that is when a different size is used, and that is a whole other level of complexity.
Groover wrote:
……. I can easily get them for the load range H tires on my motorhome but not for my pickup or any car. A while back I put high fuel economy tires on a Taurus and noticed that they were rated at 50psi instead of the 35psi on the original tires. That raised the questions in my mind of whether I had to use the higher pressure to get the advertised fuel economy benefits and were the wheels rated for it. I called customer service at Goodyear and they flat out refused to answer any questions and would only tell be to use the recommendations on the manufacture's sticker. …..
That's because if you used the same tire size, the vehicle tire placard IS their recommendation regardless of what the max pressure on the sidewall says - even for high fuel economy tires.
Groover wrote:
…... They also refused to discuss the pressure ratings of any specific tire but they did finally give me excerpts from a chart developed by that American Society of Automotive Engineers from who knows how many years ago. …….
Ah ….. Mmmmm. … SAE doesn't publish load tables. Tire Standardizing Organizations do and in the US it is The Tire and Rim Association and those tables are pretty much good forever - that is, they don't change over time.
Groover wrote:
……. When I pointed out that the chart had a lot lower pressure rating than the sidewall did for the fuel efficient tires at max load they said that going up to 10psi over was not a problem. …….
Yes, the load table is the load table for ALL the tire sizes listed in the table - even ones with higher max pressures.
Groover wrote:
…..Anyway, if you can help us find some data developed by engineers and testing instead of going by opinions I would appreciate it.
What kind of data did you have in mind?
