From the Michelin website FAQ
Must I replace my present tires with the same size tires?
Never choose a smaller size than those that came with the car. Tires should always be replaced with the same size designation, with approved or greater load carrying capacity or greater load carrying capacity -- or approved options -- as recommended by the vehicle manufacturer or authorized dealer.
The way the question is asked puts Michelin or any tire mfg into a liability corner. So sure Michelin answer to this specific question will always be the same as the Q&A answer.
Now if the question is worded differently such as in many emails from Michelin that have been posted on this website over the years we get a different answer such as this....
**In regards to the email you sent stating:
I have a 2006 Montana 5th wheel Trailer that has two 6,000 lb Dexter axles and 4 deluxe aluminum Rims each rated at 3,042 lbs. I would like to install your Michelin XPS® Rib™ LT235/85 R16/E's on this 5th wheel. Will the tires be fully waranteed in this application?
Answer..---------------------------------------------
We appreciate your request for information regarding the Michelin XPS Rib. The XPS Rib, size LT235/85R16/E, part number 13080 would be a good fitment for your 5th wheel. The tire carries 3042Lbs at 80-psi max pressure. For best pressure recommendation, run at maximum pressure until you can weigh your axles either call or reply to this email for a pressure recommendation.
It is a good application, so there are no warranty issues. Your tires are covered under applicable warranty.
We appreciate your business and thank you for choosing Michelin.**
This is old stuff and this website has been through all this many times before with Cal who was posting same non sense as FastEagle back then.
