card_cap's avatar
card_cap
LT265/70x17 E-load tires vs normal 265/70x17: pros and cons?
I'm looking to upgrade the Goodyear Wrangler RT/S on my Chevy Avalanche in the near future before I start towing a ~7000 pound trailer. All of my driving to date has been on paved roads, so I figure I'll go with a highway tire for a replacement. I have been looking at the highly rated Michelin Defender LTX M/S, but the price was a bit of a turnoff (this is my first truck, and first truck tire change so it's still a shock to me coming from passenger car tires!). The Sumimoto Encounter HT, although it doesn't have quite as many reviews on Tirerack as the Michelin, edges it out performance wise almost completely across the board for a substantially lower price, and their warranty seems as good or better. Supposedly they are the manufacturer of many other company's tires so they aren't an inexperienced, fly-by-night operation.
Now here is the conundrum - there are two versions of the tire in my size. An 'E' load rated, non-UTQG rated version at $136.20 with 16/32" tread depth(!!!) that weighs 54 pounds and has a max load of 3195 pounds or the 'normal' tire with 600 UTQG, costs $117.04, has a 'typical' 12/32" tread depth, weighs 42 pounds, and has a max load of 2679 pounds. I assume the tread compound is the same, so I'd be gaining 50% more tread depth/service life, at only 16% more cost, BUT I am adding 50 pounds of unsprung weight to my truck which will affect my gas mileage and handling to some extent. I feel like the max weight shouldn't be an issue as even the normal tires exceed my rear axle limit, however, maybe because they are heavier tires, they'll 'feel' better or actually perform better under heavy load? Or perhaps offer better puncture/blowout protection? I'm guessing the extra material goes in the sidewall so it would help prevent unrepairable sidewall tears/blowouts? Another factor to consider is my annual mileage. In the roughly 10 months that I've owned the truck, I've only put 7000 miles on it. So perhaps the tires will dry out from ozone and UV damage before I wear them out anyways?
Doing some reading of various truck/off-road/towing forums, it sounds like heavier duty tires on the tow vehicle will 'sway' less, but not really sure what this means or how the vehicle sways? Wouldn't just the trailer sway? Would the extra tread depth actually be a detriment to daily driving? Will the extra tire tread life benefits be more than cancelled out by increased fuel costs over the life of the tire?
Anyone with more experience than myself have some opinions or strong arguments about which route to go? Thanks!
  • The truck tire will have stronger sidewall and not flex as much when towing the trailer and having it pushing the rear of the truck around which causes sway. You can air down when not towing and improve the ride somewhat.
  • I dont think the compound or the structure is the same at all.
    The truck tire will give the best service but will ride harsher.
    There's always a trade-off aint there?
