mfoster711's avatar
mfoster711
Explorer II
May 21, 2017
Tires - Load Range D vs E
My trailer uses 225/75R15 load range D tires. Checked my local tire stores and all of them only had load range E tires in stock. One of the guys tried to push me into getting load range E because "they are a much higher load rating and can handle a lot more weight" and he questioned why I didn't just want the load range E tires. I told him I did not want load range E for several reasons:
  • Load range E tires have to be inflated to 80 PSI and might cause a rougher ride
  • my wheels are not rated for load range E
  • I would also need to replace my spare to ensure I don't mix load ranges
He was polite after that and ordered some load range D tires which will be in this week.
Truth being told, my wheels might be rated to handle load range E. I just didn't want the load range E tires because I thought it would be overkill for my trailer and may cause a rougher ride. My max trailer weight is 7500 lbs so I could actually use load range C and be just fine.
I am just curious how many of you would have just gone ahead and took the load range E tires they had in stock. Do you think it would make a difference in the ride?
