- GeoBoyExplorerI have used Lucas Red N Tacky on both my TT's and have never had a problem. The drop point is rated at 540 degrees and the Timkin grease mentioned is 350 degrees. Al-KO axles require 430 degrees drop point.
- path1Explorer
3oaks wrote:
In the past I also used "Fords" racing "high temp" $23.00 a tube stuff. Doesn't make a difference on trailer. Trailer axles are not that high temp of application.
I don't know about that. After seeing the way some of them fly by me on the interstates. :@
YA, I had to slow down when I quit using it:) - 3oaksExplorer
I don't know about that. After seeing the way some of them fly by me on the interstates. :@ - Turtle_n_PeepsExplorerI don't like that stuff at all. It separates like a big dog.
I use Sta-lube Hi-temp grease in everything I own. From race cars that go 140 MPH to tractors that go 5 MPH to trailers to ............well........everything I own.
I will not change because I never had a wheel bearing problem; ever. - path1ExplorerX2 on spec's from axle manufacture... The info I have on mine stated the "base" type of grease and the min "dropping" point. I ended up with Walmart "Tech" something. More than meets OEM's spec's and available nation wide, so I don't have to worry about getting right stuff or carrying it when away from home.
If your happy with what grease you have and it meets OEM spec's for axle, go for it.
If you can't sleep some night or real bored see https://www.nlgi.org/ tells you what all the tech stuff is about dropping points, type of base etc. And also bear in mind a lot of grease and oils are "snake oil". Some manufactures put more into advertising than research. - phillygExplorer III think they all show at least a bit of separation over time. I recommend using whatever the manufacturer recommends.
- 3oaksExplorer
joshuajim wrote:
As does the Mobil 1 wheel bearing grease that I use.
I would be concerned. I use R&T for greasing my tractor and I have to keep the grease gun in a plastic bag between uses because at room temperature the oil separates out and leaks red goo! I have no idea what would happen at elevated temperatures. - jmtandemExplorer II
Has anyone had experience with Lucas Red N Tacky #2 grease using it for wheel bearings, I am getting ready to replace all of the bearings on my trailer and wanted to find a good grease to use.
You did not mention whose axles you have on your coach. However, if you have Dexter axles their recommendation for grease is what I would use. - joshuajimExplorer III would be concerned. I use R&T for greasing my tractor and I have to keep the grease gun in a plastic bag between uses because at room temperature the oil separates out and leaks red goo! I have no idea what would happen at elevated temperatures.
- westendExplorerI don't use that grease but it should be fine for your purpose. For comparison, here is the data sheet for Timken bearing grease. Most of the specifications are close with either product.
44,068 PostsLatest Activity: Jun 10, 2026
