westend wrote:
Yes, more than likely, a bad converter. You will probably want to assess the health of your battery at the time you replace the converter. Any auto parts store will load test the battery.
I have a Progressive Dynamics converter. It is 44 years old and still working fine. I have no other recommendation.
If you contact Best Converters and ask to speak to Randy, he will give you the model # and pricing on a converter replacement that won't involve replacing the distribution center.
Good luck with your 12V issues. I would replace that Magnetek sooner rather than later. It may be stressing things connected to 12 V.
Many thanks to you and GrandpaKip for the help. I will check with Best Converters.
I'm keeping my fingers crossed, as DW and I are headed out tomorrow for a weekend getaway. I do keep my battery switch turned off most of the time, just occasionally charging it with the converter. So hopefully no problems there. I will make sure the battery is charged good with my charger before our trip (my TV charges going down the road, too, if I have the battery switch turned on). If the converter failed completely, the fridge and water pump, and a light or two, will need that power. I can run our ceramic heater off an extension cord. The state park we're going to has 20/30/50 amp at each site, but no water. So I need the pump.
