bigfootford
Oct 22, 2015Nomad III
Wow, great job on that install and your confidence that you could do it!
Remember that you do have that button to boost or drop the charging stage. Learn to use it.
You will find sometimes that when you plug in to shore power to charge that the PD sets its charge stage by the voltage of the battery (s). Think 12.3 is the trigger point to go into bulk/boost mode 14.4 vdc. You can just activate boost with that button and reduce the charge time sometimes by more than an hour.
When my battery (s) are hot 90deg + because of hot weather I drop the charge stage to 13.6 Absorb to keep my batteries from boiling too much.
Jim
Jim
