ticki2
Dec 02, 2018Explorer
With the cables removed from the converter , the converter plugged in , test with multimeter between + and - terminals on converter for voltage . Report results . Then with cables disconnected from converter and connected to battery check for voltage at the cable ends that where disconnected from the converter , should be battery voltage . Report results .
