Actually a residential style breaker will trip at (I'm pretty sure) 80% of the rated capacity. The other 20% is there to allow for starting up larger stuff like the compressor on your AC without tripping but if you think you can pull 30 amps across a 30 amp breaker at all times - that's just not how it works.
There are other factors such as voltage that effect how much current you are drawing (amperage) lower voltage means more amps to do the same work. An AC trying to cool off a hot space will work much harder and pull more current than one that is just maintaining a cooled space in the night.
You could also just have a bad breaker. In my most recent brand new built stick house I've had to replace one breaker and two different GFI outlets in less than three years.
