- Ron3rdExplorer IIITo the op, welcome to the club. Go to YouTube
Tons of Cummins oil change videos there - Wild_CardExplorer
boshog wrote:
Cummins12V98 wrote:
Wild Card wrote:
Bigger pain in the rear is greasing the front driveshaft.
So true!!!
BTW Cummins recommends pre filling the filter.
Googling this topic creates a huge Benjamin Franklin list. I've seen others say this too but I've never seen this published by Cummins.
I stand corrected albeit this is for an ISX engine;
https://www.cumminsfiltration.com/sites/default/files/MB10313.pdf
It is reccomended...the oil filter that is, but not required. Your not gonna hurt the engine either way. - boshogExplorer
Cummins12V98 wrote:
So true!!!
https://www.cumminsfiltration.com/sites/default/files/MB10313.pdf - boshogExplorer
eHoefler wrote:
I let the dealer do it, I can't afford not to, since they charge $68 for an oil and fiter change.
for a Cummins? Dealers here (SE Michigan) get $150.
It costs me around $73 for a DIY, $66 for 3 gallons of Rotella T6 and $7 for a Mopar oil filter. - eHoeflerExplorer III let the dealer do it, I can't afford not to, since they charge $68 for an oil and fiter change.
Cummins12V98 wrote:
- IdaDExplorer
Greene728 wrote:
Cummins12V98 wrote:
So true!!!
Ok. There is a difference between recommend and required.
There's nothing in the owners manual about prefilling. Unless I missed it anyway. - Greene728Explorer
Cummins12V98 wrote:
So true!!!
Ok. There is a difference between recommend and required. - Cummins12V98Explorer III
So true!!!
BTW Cummins recommends pre filling the filter. - Cummins12V98Explorer III
Redwoodcamper wrote:
I use the top method. Don't forget your ccv filter around 65k miles unless you delete that filter. You can have problems if you don't do either.
Yes but your truck is completely different from the 13 and up RAM Diesels.
44,068 PostsLatest Activity: Jun 20, 2026
