DiskDoctr
Aug 08, 2013Explorer
Making a "Super" canvas?
We have PUGs. Love them, hate the install/remove and how they slip from the top where the bunk meets the camper.
Last year we added adhesive backed hooks to camper to look the elastic cord over, which helped, but one has since come off.
So I got to thinking. Would there be any reason I couldn't sew these (or similar material, which can also be had from the same fella as PUGs) directly to the canvas?
I would only sew the ends onto the seams.
I thought about adding a couple of thin pieces of foam (think thinner version of pool noodles, not absorbent) in a few spots to keep the material off the canvas itself and leaving a few gaps in the sewing to act as "weep holes" for any moisture that could build up between the layers.
The reflective material is very thin, so I don't think it would be a problem folding with the canvas.
I was fortunate to pick up a couple of industrial sewing machines for a song, one of which should have no problem sewing through the layers with a heavier needle and UV thread. A friend of a friend was downsizing her shop and I got lucky.
In addition, since we are talking reflecting radiant heat, can you think of any reason why I couldn't use material that is green (or other) color on one side and put that out, if I didn't want the "tin foil" look? I don't mind the look, just trying to be descriptive ;)
I am definitely looking for opinions and thoughts or problems you may foresee. If anyone has done it, I'd really like to hear about your experience, too!
Thanks!
Thanks!
