gbsteph
Jul 05, 2021Explorer
I did the mod on my previous 2004 Lance 815. The Reico Titans worked like a champ. Mine however was not pre-wired so I had to do that myself and was able to keep everything concealed within the campers structure. So, I can't help you with pics in that department. I just mounted my controller low on the wall that forms the bathroom just inside the entry door. My controller had a positive and a ground wire going in, generally a heavy gage wire, and then 4 sets of +/- coming out to each jack. So I would assume if it's prewired, you should have that similar configuration dangling in that location. Hope any of that helps. I loved that little Lance.
